TwinTurbo.NET: Nissan 300ZX forum - Re: Per MagicMike, the only thing I can think is
outkaZTT
on December 20, 2018 at 8:18 PM
posted by MixManMash
on December 20, 2018 at 01:56 PM
Unfortunately I didn't buy the adjustable gears when I did my build. Regretting it now.
Help diagnosing A/F ratio differential between passenger
SirpriZ
18:10:00 12/18/18
Re: Help diagnosing A/F ratio differential between passenger
MagicMike
18:54:56 12/18/18
This. I see a difference, especially at idle between the
MixManMash
21:50:11 12/18/18
Do you see differences between the banks under different
SirpriZ
12:40:27 12/19/18
Mostly under idle, light/cruising loads.
MixManMash
19:04:20 12/19/18
Thanks. With Haltech you can adjust A/F ratios from
SirpriZ
19:48:30 12/19/18
MixManMash
13:56:30 12/20/18
Re: Per MagicMike, the only thing I can think is -
outkaZTT
20:18:30 12/20/18
Don't regret. You can still buy them. But you'll only
MixManMash
07:17:58 12/21/18
I should mention this is vorpalZed (vorpalZ formally)
MixManMash
10:13:04 12/21/18
Re: Don't regret. You can still buy them. But you'll only
outkaZTT
17:46:33 12/21/18
Thanks for the reply!
outkaZTT
09:54:12 12/19/18
Talk to SZ, but I'm very sure they run serial setups on high
MixManMash
19:06:17 12/19/18
Re: Talk to SZ, but I'm very sure they run serial setups on high
outkaZTT
19:31:44 12/19/18
typically at idle / low speed it usually is a function of a
The Devils Z
09:19:48 12/29/18
Thanks for the reply as well. You stated you have certain
SirpriZ
12:44:51 12/19/18
Re: Thanks for the reply as well. You stated you have certain
MagicMike
17:39:03 12/19/18
I am wondering if a difference in cam timing from bank to
SirpriZ
19:12:09 12/19/18
Re: I am wondering if a difference in cam timing from bank to
MagicMike
20:03:24 12/19/18
